FlexLogger
Retrieving analog input channels that were mistakenly not logged
I have a test running that was supposed to consist of analog input channels sampling at 250 Hz. All my analog input channels have calculated 1 second mean channels linked to them. For a previous long (multi day) test, I had turned off logging on each raw analog input channel to save on file size. Basically, only logging the 1 second means and other calculated channels. I started this test without resetting the logging on these channels. Is there any way to recover data from these channels? Is it saved at least temporarily before being written to a file? Thanks.
Message 1 of 1
(141 Views)
