Forum Italiano sui Prodotti NI
annulla
Visualizzazione dei risultati per
Cerca invece
Intendevi dire:
PID Control Single Channel
I’m using the “ PID Control Single Channel “ example (example\DAQmx\Control ).
I’m generating un external signal (a sine wave) by un external source and the signal is acquired from the Input Channel of a DAQ (NI USB-4431).
Un error occurred at the property node  (code -200077, please, see the attached file).
The suggestion is to select “the onboard clock” on the input channel, so I did it…but I’ve still got the same error.
Please..if you have any suggestion it would be very helpuful.......
thanks
Barbara
Messaggio 1 di 3
5.841Visualizzazioni
try to eliminate the block "Get terminal name with device prefix".
Connect the "source" terminal of the "sample clock" block to the dev1/ai/sampleclock
Let me know if this help
Alex
Messaggio 2 di 3
5.827Visualizzazioni
I did it as you suggested but it didn't work.
I've connected the source terminal of the sample clock to the dev1/ai/sampleclock ...but it didn't work.
Please see the attached file.
Any other suggestion?
thanks anyway
Messaggio 3 di 3
5.769Visualizzazioni
