G Web Development Software
Export to excel
Hello, I am a beginner of labview and G web development.
I am now developping the web application.
Is it possible to export the array to excel ? if you have a code to be share with me, it is very pleasure.
(2,268 Views)
Accepted by mmm21
Hi mmm21,
We do not have an direct workflow to export the array data to excel in GWeb. However the use case you are trying is possible through the library available in https://forums.ni.com/t5/Example-Code/File-for-WebVI/ta-p/4129229 .
I have used the above library and converted a array constant to csv. This WebVI when run on the browser will download the csv for the array. Hope its helpful.
Note : The example was created on the latest GWeb version
(2,227 Views)
Thank you ! It is very helpful for my web application.
(2,206 Views)
