G Web Development Software
Have a question with port
The web address is use gwb made
The position selected by the red box(56587) changes each time the server is restarted, making it impossible to use the same address to connect to this web address.Can anyone tell me what to do?Thanks.
(139 Views)
Accepted by HavisZhou
Hi HavisZhou,
The URL you see while testing in the G Web Development Software editor is only used during development. When you have finished development you can deploy your application to a Web Server for hosting so others can connect to the WebVI. The Hosting a Web Application on a Server discusses several options for hosting a built WebVI.
If you are just getting started with G Web Development Software I'd recommend watching the How to Build a Web UI for Your LabVIEW-Based Test System presentation for an overview of the services included with G Web Development Software and the different hosting strategies.
Milan
(106 Views)
