G Web Development Software
LabVIEW and G Web Development Software on the same Windows
Dear NI Experts,
I am a LabVIEW Community v2021 user.  I can do simple Labview programme.
I've found that there is a new G Web Community version.
  1. So what are these 2 software's relationship?
  2. Can they exist in the same Windows 10 OS?
  3. Do they conflict with each other?
  4. If I can run Labview Community v2021, do I still need G Web Community?
  5. Is there MQTT plugin supported in G Web Community?
Thank you in advance.
(5,577 Views)
Accepted by HKPhysicist
    1. They are separate applications, that can be used together.
    2. The G Web Development Software gives you the ability to publish web pages using G (LabVIEW's graphical programming language). If you are not familiar with web development environments (HTML, CSS, JavaScript, etc.), this is a great benefit.
    3. The look and feel of the block diagrams is different from LabVIEW 2021, but it is still G.
    1. Yes, they are different applications.
    2. As a developer you could create an application in LabVIEW and use the G Web Development Software to create an 'application' that publishes the data to the web.
    1. No. See answers to question 2.
    1. No, but LabVIEW 2021 and G Web allow developers to implement different functionality.
    1. I am not an expert on RabbitMQ which MQTT is part of.
    2. My educated guess, you will need to create JavaScript code to communicate with RabbitMQ from the G Web development Software. Someone else may have more experience on this topic.
To summarize, download the Community version of the G Web Development software and try it out. There are examples included and online, along with tutorials.
(5,553 Views)
Thank you!  Very clear explanation!  😀
(5,539 Views)
MQTT is a communications protocol that's often used for IOT devices (but I've used it in more general scenarios).
LabVIEW can easily do MQTT with add-on software.  Use the VIPM tool (VI Package Manager) to look for MQTT add-ons.  I use the one by Francoise Normandin.
I don't know of a MQTT add-on for G Web software.  In my experience, I've used MQTT to communicate on the backend, not to frontend software such as what you would create with G Web.  That's not to say you can't do it, but I don't think it's as common a use case as, for example, a bunch of devices wanting to send data to a database backend, which can then publish data to a frontend with JSON or another data format.
Brian Powell
Stravaro, LLC
Learn more about the DSH Pragmatic Software Development Workshops.
(5,486 Views)
Yes, I also feel that a Windows exe program will be much faster than a web browser with the same MQTT functionality.
I will stick on Labview 2020 and see what I can do!
I have also installed those MQTT addon from within VIPM.
(5,449 Views)
