G Web Development Software
Questions about errors
I'm new to this software, so I can't tell if the problem is me or the usability of the G Web software.
Q1:  How do I see more of the "Message" in the Output window? I can't seem to horizontally scroll (though if I resize the window, I momentarily see a scroll bar, but it disappears almost immediately).  There's no tip strip, either.  I also can't seem to make the window any wider than my screen.
Q2: What's the difference between the Output window and the Errors and Warnings window?  The "Errors" shown above don't show up in the Errors and Warnings tab.
Q3: When I right click on an error indicator on the panel and select "Explain Error", nothing happens.  What am I doing wrong?
Brian Powell
Stravaro, LLC
Learn more about the DSH Pragmatic Software Development Workshops.
(2,140 Views)
Hi Brian,
  1. You are right, the usability of this window needs some improvements. I have created a bug to address this.
    In the meantime, here's a workaround that should help: when you select a row and hit Ctrl+C, the content gets copied to clipboard which you can then paste in a text editor.
  2. The Errors and Warnings window populates any VI/webVI compile issues such as unwired nodes, incorrect data-type wired to a node, etc.
    The Output window mostly populates the errors that crop up when running the VIs in the editor. e.g. a JavaScript function invoked by JSLI might have thrown an exception. When you build a web application and run it in a web browser, these messages will get logged in the browser's console.
  3. It's a bug, the correct behavior is to show a dialog with more details. I created an issue to address this. The errors listed in this page might help in the meantime. Unfortunately I think the page might not list all the errors which G Web Development Software can list.
Sujay Narayana
Principal Software Engineer
(2,107 Views)
