G#
Bug??
Are you changing the inheritance using the G# IDE or are you changing it using the LabVIEW tools?
You should be doing everything through the IDE (right click > g# IDE) this includes making you classes.
Depending on what you want to do, you may also need to define your class as 'abstract' when creating it.
Message 11 of 18
(10,992 Views)
All my operation Using G#IDE
Message 12 of 18
(10,987 Views)
This is the change-inheritance bug in LV2020 I explained in https://forums.ni.com/t5/G/Inheritance-Error/td-p/4086662
The solution is in that thread.
Certified LabVIEW Architect
Message 13 of 18
(10,979 Views)
it seems that not this bug。
Message 14 of 18
(10,974 Views)
1. create queue_class Inherit  from G#
2.create UI_class Inherit  from G#
3. change UI_class  Inherit  to queue_class
4.create a test vi, this vi content is create a UI_class  ,then call dequeue method  it occur errors ."
I did exactly that and the inheritance error is the only error I get. Please post code that can produce the error you are seeing. The code you posted throws an error but for a completely different reason than what you are explaining, and the reason for that error is already explained and has nothing to do with G#. Is that the error you are referring to? Are you getting a dialog from the LabVIEW IDE or an error code on the error wire? What error code is it?
Message 15 of 18
(10,964 Views)
  Until the third step, Does UI_create VI include Queue_Create Vi?
Message 16 of 18
(10,933 Views)
Accepted by yanzhanglin
Ah, I see what you mean now. When changing inheritance from G#Object, the Create-method of the base-class is not inserted. It has likely been like this since forever and no-one was bothered enough by it to report it.
The workaround is to insert it yourself, as you have found out.
I have added this issue to the issue-list for G# and have talked to the main developer about it and hopefully it will be implemented in the next version of G#.
Message 17 of 18
(10,931 Views)
I think deep clone method
and when we create property,we can create all property at one time,
and if we change objectAttribute members,we can just update property,it will change all create property VI。
Message 18 of 18
(10,928 Views)
