G#
does G# resize the connector pane ?
LV 2011
I am not sure when I recognized that my default connector pane is no longer 4x4x4.
I noticed although that the G# methods generally use a higher count of connectors and wondered if this is really necessary.
Then I saw that collapsing code to a sub VI also sets the the new pane to 6x6x6.
This is VERY inconvenient especially now tha NI has decided to stick to 4x4x4.
I found by now where in LabVIEW.ini I can reset that default but as soon as restarting LV it is back to 6x6x6.
So I wonder who the culprit is ?
Regards
Gabi
7.1 -- 2013
CLA
(5,560 Views)
Yes, G# actually does this. Default is 6x4x4x6, but you can change this is Tools->G# IDE->Options... and then use the standard 4x2x2x4 pattern. All generated G# methods will have this pattern as selected. We did change this in G# Framework 1.4.0.
The reason is the new improved "Create Sub VI" feature in LV2011 that G# "hooks" into when creating a subVI will be created with the default connector pane pattern i LabVIEW. In order to get this feature correct in G#, we did set the default pattern in LabVIEW to the same settings as in "Tools"->"G#IDE"->"Options", else the new hook for "create sub VI" wouldn't work as expected. I did have some discussion with NI regarding this, but this is the way it works now. If you set the G# options to 4x2x2x4, it will be back to 4x2x2x4 as default settings.
/Mattias
(4,257 Views)
