GDS(Goop Development Suite)
Active Object Does not Shut Down properly in an Executable
Michael,
I am using active object in my classes, it works perfectely in development mode. But when I use it in Run Time and try to exit the application, the program has a lot of trouble to shut down the active object and most of the times when I exit the application, it freezes with a message saying " RESETING VI"..... and the vi it is being referred to is the Active Object vi. Any clues in how to solve this?
thanks
(6,072 Views)
There is another loop running in active class.You can use Start Process.vi to run the process loop.also you can stop the loop use StopProcess.vi.I think it is not use StopProcess.vi in your class Destroy.vi . You can also check you process.vi  to find it can reponse the queue cmd msg of StopProcess.vi correctly.
(6,026 Views)
Yes, I agree.
The problem was that not all instances of the class with the active object were being destroyed, which resulted as you said, in loops left in memory. In the development mode somehow this were taken care and I did not even noticed, as labview shutdown these  loops. However, in executable mode, there will be an RESETING VIs problem if the active objects are not properly destroyed I realized this using the Desktop Execution Tracer tool kit by certifying myself that all instances of classes with active object were destroyed while in development mode. To my surprise, I exited without destroying some instances, and after I shut down everything properly the problem is gone forever!
thanks for your help
(6,015 Views)
