Hardware Developers Community - NI sbRIO & SOM
Clock import on the reference carrier board
Hi all,
I'm using SOM with the reference carrier board and want to import some clock from an external hardware. The clip generator tutorial states that we should use only the clock-capable pins to import clock sources. But the prototyping area on the board doesn't have any clock-capable pin (DIO64 - DIO87). Any suggestion?
Regards
(4,713 Views)
Per Table 19 in the SOM specifications, DIOs 84, 85, 86, and 87 are clock capable and in Bank 3, which is exposed on the prototyping area.
spex
Spex
To the pessimist, the glass is half empty; to the optimist, the glass is half full; to the engineer, the glass is twice as big as it needs to be has a 2x safety factor...
(4,345 Views)
Spex,
Thanks. I missed it.
Could you point me to where i can find some example code.
I'm trying to read IQ data from a transceiver. The transceiver outputs IQ data (12 bits two's complement) and clock.
(4,345 Views)
