Hardware Developers Community - NI sbRIO & SOM
Error sbRIO-9651 compile worker
  I have sbRIO-9651 Reference Carrier Board. I have installed LabVIEW 2014 SP1, 2014sp1RealTime, 2014sp1LVFPGA, cRIO driver. Also I have installed xilinx compilation tool Vivado 2013.4 as mentioned in this  https://www.ni.com/en/support/documentation/compatibility/19/compatibility-between-xilinx-compilatio... . But when I run sbRIO-9651 CRB Getting Stareted.lvproj (Example Finder) using Compiling on local compile server, I get the error:
[::ERROR: [Common 17-345] A valid license was not found for feature 'Synthesis' and/or device 'xc7z020'. Please run the Vivado License Manager for assistance in determining
which features and devices are licensed for your system.]
    I don't know what I am missing....
(4,949 Views)
I've seen a couple past situations where this error was caused by the time/date being incorrect on the PC. If the date is too old it could cause issues with the Vivado license. It's worth verifying that the date is set to sometime relatively recent.
Will
(3,875 Views)
