Hardware Developers Community - NI sbRIO & SOM
Needs some advice on using SATA with sbRIO-9609
Thank you very much for the information.
But this is not seems like my problem because monitor works in Ni Linux RT. My monitor does not show anything only when I go into the BIOS according to the instructions from the NI documentation.
I press Del or F10 and sbRIO-9609 starts starts flashing the status LED, but I do not see anything on the monitor.
Message 11 of 14
(2,401 Views)
Everything works if you use an USB Typr-C - VGA adapter.
Message 12 of 14
(2,375 Views)
Hi, Vinograd
Sorry for replying late. I could not log in NI Community in the past weeks. I don't know why.
What I was using is a Type-C extension dock as shown below. I connect it to the Host Type-C port on 9609. And I connect my keyboard to the dock and a VGA adapter to the monitor. Everything was working fine.
Richie
Message 13 of 14
(2,369 Views)
Thank you
Message 14 of 14
(2,355 Views)
