Hidden Gems in vi.lib
Is Name Multiplatform.vi - why you're hiding from us?
OK, I know why "Is Name Multiplatform.vi" (vi.lib\Utility\libraryn.llb\Is Name Multiplatform.vi) is not available in palette. I know that thanks to "Hidden Gems in vi.lib.pptx" But anyway this is quite useful VI for filename validation and it looks like properly developed VI, so why not to add it to the default set of VIs?
This is situation similar to "Check Prime.vi" subject... Darren maybe another CAR?
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
(11,867 Views)
I have filed CAR 554363 to get the Is Name Multiplatform VI added to the Advanced File IO palette in a future LabVIEW release.
(10,662 Views)
This function is super handy and I've been using it for years.  One thing I also did was made a subVI that uses this function, which accepts a path, and then turns that path into a multiplatform compatibile path, instead of just checking the file name.
(10,662 Views)
Look for Is Name Multiplatform.vi in Quick Drop (and on the Advanced File Functions palette) in LabVIEW 2016!
(10,662 Views)
