High-Speed Digitizers
5911 self cal reports a problem w/ the temp stab circuit. not due to pc -12V
I have three 5911 scope cards in a test pc and one generates a temperature stabilization circuit error when self cal is ran and times out when operated through NI-MAX test panel.  I have swapped card positions and the problems follows the card.  Is the card repairable?
(5,959 Views)
Without seeing it, we don't know, but it sounds like it could be repaired.  Contact your nearest National Instruments service department and send it in.
(5,952 Views)
