High-Speed Digitizers
Variable DC level output on PCI-MIO-16E4/PCI-6040
Hello there,
Does anyone have an idea on how I can make the PCI-MIO-16E4 give me a constant DC level at a predetermined voltage?
I need to control a unit that uses voltage from about 20 mVDC to 2.3 VDC.
All the examples i've found use either a sawtooth, triangle, square or sine wave and i've got that working nicely, but none seem to mention a DC output which I need for this project.
Friðgeir
(6,832 Views)
That just requires a DAQmx Write set to 1Chan 1Samp (assuming LabVIEW). The input is a scalar.
p.s. Your board is not one of the High-Speed Digitizers/Scope boards. The multi-funciton DAQ board would have been more appropriate. Also, next time mention the language and DAQ functions you are using.
Message Edited by Dennis Knutson on 01-13-2010 03:48 PM
(6,831 Views)
Dennis,
Thanks for the quick reply. Sorry about the confusion with the boards.
(6,825 Views)
Oh yeah, i'm using LabVIEW 8.5.
(6,823 Views)
Hello Fridgeir,
If you want a pre-built example that implements this type of application you could take a look at the Gen Voltage Update VI. This can be found in the Example Finder under Hardware Input and Output»DAQmx»Analog Generation»Voltage.
Dan King
(6,820 Views)
