High-Speed Digitizers
AT-5102 scope card
because of hardware failure, trying to get my old
AT-5102(ISA)cca to work in the short term, Have back reved LV to 5.1 loaded 6.1 NI-DAC, reprogrammed code under 5.1 platform. Code shows no error. Problem is the system (instrument wizard) does not see the cca. Do I need a driver? any ideas why I cann't get the thing to work. Platform is win 98.
Earnest Bertram
(6,237 Views)
The AT-5102 card is supported by NI-DAQ 6.1. You are using the correct driver, but it may have been installed incorrectly. Please try reinstalling the driver.
Andrew A.
(6,237 Views)
