High-Speed Digitizers
Error FFFC822C at niScope_FetchBinary16
After upgrading NI-SCOPE from 3.7 to 3.8, this error started to occur intermittently:
Possible Reasons:
Internal Software Error occurred in MIG software. Please contact National Instruments Support.
Component Name: nihsdrk
File Name: p:\Measurements\DHV\DIDE\export\2.5\2.5.1f1\includes\nidide\memory\tFetcher.cpp
Line Number: 394
Two channels are used in continuous mode, with high speed (1Msample/second each).
What is tFetcher doing at line number 394?
(5,771 Views)
Dear Ali65,
  It seems something went wrong during installation of the driver. At least I would try to uninstall and than reinstall the driver. If it still exists, I would try to reinstall the 3.7 version driver to see, if we have problems with 3.8 driver itself, or something went wrong in the system.
Please try these reinstallations and let me know the results!
David Varga
NIH
(5,764 Views)
I have installed NI-DAQmx Version 9.3 on this test PC.
Is it possible that installing NI-DAQmx installation corrupted the NI-SCOPE setup?
Can I have both of NI-DAQmx and NI-SCOPE products installed on the same test PC?
Do they need to be installed in a specific order?
(5,762 Views)
Hi Ali65,
  You can have both installed on the same PC, they shouldn't bother each other. Even the order is not relevant question when it comes to drivers. Though it is important to install first the development environment(ex.:LabVIEW, LabWindowsCVI)and than the drivers.
  I don't think that DAQmx installation corrupted NI-SCOPE, however just in case I would reinstall both after uninstalling them.
Let me know what were the results!
Best,
David Varga
NIH
(5,758 Views)
