High-Speed Digitizers
How can I access nitclk with vb6?
I'm trying to use niscope and two PXI-5122's but apparently niscope doesn't control synchronization of these cards I must use nitclk. However I don't see any support for vb and nitclk. Can I interface to nitclk.dll in vb6 and what declares must I use to do so?
Thanks.
(6,536 Views)
Hi RobFarrell,
There is no direct support of NI-TClk in Visual Basic. NI-TClk enables customers to access its functionality through C functions, and at a higher level, LabVIEW VIs. However, I suppose it would be possible to use NI-TClk C functions if you knew how to create an import library for Visual Basic.
There may be consequences to that I don't know about. Like does Visual Basic support 64-bit data types, such as Float 64? There must be a reason there is no support for VB.
Hope this helps!
Chad AE
(6,526 Views)
RobFarrell,
One of our engineers has recently developed a first generation example using NI-TClk with Visual Basic to synchronize two NI PXI-5122s. It shows in code how to interface the C function calls. I'll include it below.
(6,517 Views)
Code to synchronize two PXI-5122s:
(6,502 Views)
