High-Speed Digitizers
How to delay a trigger with PXI-5122 before routed to PFI line
Yes, when using a reference trigger, the trigger timestamp uses the trigger event at time 0.  Thus all pre-trigger samples are negative, and post trigger samples are positive.
Systems Engineer
SISU
Message 21 of 24
(3,547 Views)
Hi Nathan,
In another setup, the Dev_1 trigger both the digitizer (via TRIG connecter) and the Dev_2 at the same time. You can see the signal (received signal caused by Dev_1) is actually there. (1)
Here is the result of the current setup: (2)
If the Dev_1 only trigger the digitizer, there are no signal. (3)
From the setups (1), (2) and (3), I found out the reason is that the Dev_1 couldn't trigger the digitizer via PFI 0. Follow the help file, the PFI 0/1 are the digital trigger lines, while the trigger from my Dev_1 is analog. So it may be the problem.
I'm trying to find the solution. Please let me know of your suggestions, if you have any.
Have a good day!
John C.
Message 22 of 24
(3,541 Views)
I find out two ways to solve this problem. The first requires another board followed this topic. The second one is fabrication a mini-circuit to convert the analog trigger signal to digital signal before routed to PFI line.
Hope this help!
John C.
Message 23 of 24
(3,525 Views)
What does your trigger from dev_1 look like?  In our entire discussion you depicted it as a digital pulse, so if it is not a digitial pulse, what is it?
If we have to acquire it as an analog signal, on TRIG, then it can only be a reference (stop) trigger, and we cannot implement your timing and acquisition like that.
Your solution to create a comparator circuit is a good option, and using another board to acquire the post-export-delayed-trigger signal would also work, export a signal to Device_2 and seccond_5122_board .
A third option would be to use the PXIe-5170R or PXIe-5171R, which using LabVIEW FPGA, you could acquire the data, and create a delayed signal easily, since the hardware is open for custom implementations on the PFI lines.
https://www.ni.com/en-us/shop/model/pxie-5171.html
I hope this helps,
Nathan
Systems Engineer
SISU
Message 24 of 24
(3,504 Views)
