High-Speed Digitizers
How to get the parameters to NI-Scope used by Auto Setup.
I need to know what values the Auto Setup in the IN-Scope lib has set. Is there an easy way to do this?
The most inportant for me is:
Vertical range, Sample rate & Trigger level
(6,947 Views)
Hi Erlis,
Try using a property node and wire the instrument handle to it, you can then read any of the properties set within the instrument.
Hope this helps,
Nick
(6,947 Views)
How do I select wich channel the property shall read from?
(6,947 Views)
Found it 🙂
Just set Active Channel to the channel you whanna read from.
(6,947 Views)
Here is a group of VIs I wrote to solve this problem. You usually need to make minor changes to them with each NI-SCOPE release.
(6,947 Views)
Thanx alot, unfortunately am I only using Labview 7.0 you don't want to convert the vi's to 7.0?
(6,947 Views)
My apologies. I should have asked. Here is the 7.0 version.
(6,947 Views)
