High-Speed Digitizers
How to measure ripple using DVM
What's the best way to measure ripple using DVM (PXI-4072)? My customer's limits are Vp-p so I think digitizing it would be the best way, but I also think that measuring true RMS would also be a good way to measure it. With digitizing the signal there's some post-processing required. Would calculating just V peak to peak in acquired signal be sufficient?
Thanks for any comments,
CT.
(7,901 Views)
I would use AC measurement and if SMPS are involved measure with highes possible bandwidth to get the spikes. Vpp ripple can be a very nasty value, a well defined setup is needed to get reproduceable results.
(A nice soucre: AN118 from www.linear.com
Greetings from Germany
Henrik
LV since v3.1
(7,891 Views)
Hi CT,
To measure ripple, you should be able to use the digitzer mode of the 4072 to measure signals up to 1.8 MS/s.  As long as your ripple voltage is not a higher frequency than that you will be able measure it.  The Developer Zone article linked here gives some more information about DC power  supplies and some considerations for measureing ripple.
Jim Schwartz
(7,876 Views)
Thank you Henrik and Jim for your help.
One more question. Should I use AC coupling for waveform acquisition, to filter out any DC that will be present (as it is a DC power supply). Or using AC coupling can alter my signal so I need to use DC coupling since the calculation Vp-p=V(Amp Max)-V(Amp  Min) will automatically remove DC component. The only concern is using 100 VDC range (for 12V PS) but to really measure mV.
Thanks again,
CT
(7,864 Views)
Hi CT,
Using AC coupling does nothing more than filter out DC components of the signal with what amounts to a capacitor.  You should be fine using AC coupling for your ripple measurement.
Jim Schwartz
(7,845 Views)
