High-Speed Digitizers
I cannot use my pci5112 card with LV ver. 6.0
I'am trying to use my pci5112 card with LV 6.0 using the DAQ solutions. I get a message saying that I have not configured any DAQ devices. When I launch MAX I see the card there and the test panels are ok.
I have the niscope1.6 driver installed.
Any ideas?
Thank you in advance.
(6,432 Views)
The PCI-5112 can only be programmed with NI-Scope. That's why the PCI-5112 does not work with the DAQ Solution Wizard.
Fortunately, there are lots of good examples for NI-Scope in LabVIEW. You can find these in the C:\Program Files\National Instruments\LabVIEW 6.0\examples\instr\niScope directory. I would recommend starting with the Configured Acquisition example and then going from there depending on the needs of your application.
Hope this helps,
Jack
(6,431 Views)
Thanks for your answer.
(6,432 Views)
