High-Speed Digitizers
Installation of mask feature for NI PXI 5114
I would like to install Mask feature for PXI 5114 Oscilloscope. Are there any mask modules that are compatible with PXI 5114?
For example, TDS3034B Oscilloscope can be installed with TDS 3TMT Mask feature.
Any suggestions/advices are welcome.
Thank you!
(3,888 Views)
Accepted by Pretty91
I looked at the accessories listed on our product page for the PXI 5114 (see the link and hit continue after selecting a module) and didn't find any additional modules.
PXI Oscilloscope
https://www.ni.com/en-us/shop/model/pxie-5114.html
However, you may be able to set up a mask in LabVIEW. I was able to find the following link which may be what you are looking for.
Limit Mask Test Example
https://forums.ni.com/t5/Example-Code/Limit-Mask-Test-Example/ta-p/3996040
If you can expand a little bit on what you are planning on specifically working on/want out of the this mask, I can try and find a more definitive answer.
Ryan M
(3,822 Views)
