High-Speed Digitizers
Installed application failes to initialize
My application works fine when installed on my computer which also has CVI Installed. When the application is installed on a different computer, it fails to initialize. I have selected the low level support drivers to be installed. However, the dll files associated with that do not get installed along with the rest of the program. Thus, when started an error message says it cant find dll files. After copying the dll files into the application directory. I get the following error type: LWTCPJSOCKWNDYCLASS: RealtimeAnalysis.exe - Application error. The application failed to initialize properly (0x0000142). Click OK to Terminate application.
(6,275 Views)
I would check in Add and Remove Programs to see if the drivers were actually installed. If not, you can try to install them manually. Most of our drivers are free downloads that you can find on ni.com/support.
(6,275 Views)
