High-Speed Digitizers
Is relativeInitialX valid for externally triggered measurements? NI PXIE 5122 64MB per channel
For instance when using the following commands
niScope_ConfigureDigitial (with a positive delay time)
NiScope_SetAttributeViInt32 ( NISCOPE_ATTR_FETCH_RELATIVE_TO to NISCOPE_VAL_READ_POINTER)
followed by
niScope_FetchBinary16 (looped to retrieve data plus wfmInfo)
What will the value of the wfmInfo.relativeInitialX prior to the external trigger?  Is it defined?  Is it set to a fixed number to indicate triggering has not occurred until the trigger has been received and then it becomes accurate after the trigger has been received?
I would like to use this to do a modified FecthForever but synchronized to an external trigger for waveforms up to about a  minute.
It seems the trigger delay for the 5122 should be able to hande a minimum trigger delay of about 170 seconds (at max sample rate more at lower rates), so the data I would need could all be borrowed from the prefetch buffers of the externally triggered and properly post trigger delayed measurement.
Thanks in advance for any advice.
Greg
(5,868 Views)
Accepted by blakney
In the case that you are fetching pre-trigger data (fetching data before a trigger has occured., relativeInitialX will be the same value as absoluteInitialX.
Nathan
Systems Engineer
SISU
(5,817 Views)
You are exactly correct. I will use the transition from equality to inequality to signify the physical trigger location.
(5,788 Views)
