High-Speed Digitizers
Multi Record Fetch Stream to Disk in C#.NET?
Hi everyone,
I am trying to fetch data and stream to disk continuously with my 5114 digitizer using multirecord acquisition.  I found a great example https://decibel.ni.com/content/docs/DOC-3441 that seems to do exactly that, using queues.  I am wondering if this same example might be available somewhere in C# (any version).  If so, could someone point me to it?
Or, if there is some kind of basic example somewhere of how to do producer-consumer queues in C#, that would also be really helpful.  (We are not running in LabView partly because we need to make custom changes to our data format as needed).
Thanks for any thoughts,
Penny
(6,582 Views)
Accepted by Penny
Penny,
Do you see the .NET examples that are under Start>>All Programs>>National Instruments>>NI-SCOPE>>Examples>>.NET ## Languages Support (## is replaced by the .NET version number)? In this folder there are a couple StreamToDisk examples. You should be able to modify your NI-SCOPE driver install to include support for .NET examples. You may also find the .NET Class Library downloads helpful if you don't already have it.
http://search.ni.com/nisearch/app/main/p/bot/no/ap/tech/lang/en/pg/1/sn/catnav:du,n8:3465.40.173.930...
Robert B
RF Product Support Engineer
(6,575 Views)
Hi Robert,
Thanks, yes I have all of those NI-Scope C# examples.  I will play around with them.
Penny
(6,565 Views)
Hi Robert,
Now that I look more closely at the NI-Scope C#.NET example MulipleRecordFetchMoreThanAvailableMemory.2010, I see that this structure is already in place.  Thanks again.
-Penny
(6,559 Views)
