07-13-2008 04:35 PM
07-14-2008 08:12 AM
08-14-2008 02:09 PM
Hi
Thanks for the reply. I did not get the Scope part. Also our signals are analog. So right now I am using a ORTEC Time to amplitude Convertor(single stop) . I was thinking more along the line of Multi stop TAC. Also How i am supposed to Clock the event. And I was looking for the device to convert the time difference between the various pulses to convert to pulse which will be fed to Pulse height analyzer(MCA) where the information will be binned in different channels. Can you suggest me something on these lines
thank you
08-15-2008 08:49 AM
You can do everything you want to do with a single dual channel digital oscilloscope and some relatively straightforward programming. The instruments you mention are hard-wired versions of the same thing, but lack the flexibility of the digital oscilloscope. I believe the following will work for you.
All of this assumes some sort of computer based data acquisition system is in place. If you are only using standalone instruments with no computer control, you will require a specific, multi-stop TDC. I would recommend against this, since the price of the TDC will probably be comparable to the digital scope (assuming you do not already have one) and you can reuse the scope for other things. I implemented a similar system using an embedded PDP11/23 over twenty years ago, but modern software environments make things much easier (LabVIEW would have cut six months off my time as a graduate student). Are you using a computer based acquisition system? If so, what is the operating system and acquisition software you are using?
If you need more help, let us know.
NOTE: I am a National Instruments employee, so I am biased. However, in my years as a graduate student and industrial physicist, I have written data acquisition systems in assembly, FORTRAN, various flavors of BASIC, C, C++, and LabVIEW. In my opinion, LabVIEW beats them all.
08-22-2008 03:26 PM
Hi
Thanks again. So the next question I have is the kind of scope I should go for. I have a Tektronix -TDS 210. I am thinking of buying TDS 1012B .This has a communication port to the PC. Then I would probably need a Data acquisition system(?) from NI. Can you suggest me that too, please? I have never worked with Labview but one of my friend hasexperience and he has agreed to help me out. Thanks again for the reply
saurabh
08-25-2008 08:23 AM - edited 08-25-2008 08:24 AM
The TDS-210 has an option for a communications port (TDS2CM Communications Extension Module). From your answer, I will assume you do not have this. The TDS-1012B looks like it would probably work for you. It is fully supported in LabVIEW. However, before recommending anything, I would need to know what sort of timing accuracy and/or pulse widths you are measuring. Make sure whatever you buy is fast enough and has enough time accuracy. Another thing to watch for is that most digital oscilloscopes have 8 bit digitizers. This is good enough for most applications, but you may require more. For example, if you are analyzing a small peak on a large background, 8 bits (256 levels) will probably not be enough. Finally, look at the signal length the oscilloscope can store in a single trace. Your application may benefit from a relatively long capture time. Many older digital oscilloscopes only have a 1024 or 4096 point buffer. Make sure the instrument you pick can handle the data length at the time resolution you require. Plan for the future. This instrument will be around long after your current project is over.
Finally, I have to put on my National Instruments hat and recommend you check out our digitizers. These digitizers plug into your computer and use the computer as the display. They are somewhat more flexible than a traditional instrument in that you can easily use them as building blocks for another instrument type (e.g. lock-in amplifier, vector voltmeter, multi-channel analyzer, pulse detector, ...). Data acquisition performance tends to be higher than conventional instruments. However, you need a computer to use them and they are not as easy to just play around with (no knobs
), so traditional instruments are better in this regard.
Let me know if you have any more questions. My apologies about not being more specific in my first paragraph. Our network was just upgraded and I am having difficulties connecting to parts of the Tektronix site, so could not get the specs for the 1012B.
