High-Speed Digitizers
NI-9205 Unused Inputs
I am only using a few inputs on a NI-9205 16 bit A/D module in a cDAQ chassis.
Are there noise considerations from unused inputs floating and not tied to ground?
If so should all unused inputs be tied to ground directly?
(6,384 Views)
Hi Duchess,
Welcome to the NI forums!
Leaving the unused inputs unwired will have a negligible effect on your measurements. Best practices wiring, however, asks you to wire them to the COM pin.
Joe Friedchicken
NI Configuration Based Software
Get with your fellow OS users
[ Linux ] [ macOS ]
Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
(6,370 Views)
