High-Speed Digitizers
Multiple Ni scopes errors
Hello friends,
 I am using the NI PXI-1031 chassis
NI PXI-8108 Embedded Controller,
NI PXI-5124 2- 4 channels
 NI PXI-6259 1
 I am facing the problem. i am trying to read the data from 2 dizitizer cards for all 4 channels the following error is comming (Error-1074126845 occured at niScope Multi Fetch WTD) the description of error is maximum time exceeded before the operation completed. Status Code :-200284).Two channels i am getting the expected data remaning two channels getting the following error(Error -1074126845).
 When i am reading the data from the single NI PXI-5124 card i am getting the data and not founding any error. i am attacing the code and the errors.
 Kindly give me the reply as early as possible.
Niranjan.h
Message 1 of 1
(6,327 Views)
