High-Speed Digitizers
NI Scope Error-1074126845
Dear all Friends,
I am using the NI PXI-8108 controller, LabVIWE 2010 and digitizer NI-PXI 5124. i am facing one problem . When i am running the code the following error is comming (Error-1074126845 occured at niScope Multi Fetch WTD) the description of error is maximum time exceeded before the operation completed. Status Code :-200284.i am attacing the code and the error. I tried with the example code. With the example code also i am facing the same problem. In the Measurement and explorer  i am not facing any problem and i get the expected  measured values.
Kindly give me the reply as early as possible.
With regards,
Niranjan.Ch
(7,819 Views)
Hi Niranjan,
Please refer to these two links for the attached error.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019LabSAE&l=en-US
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P8XsSAK&l=en-US
Hope this is helpful.
Cheers.!!
(7,799 Views)
Hi cheers,
Thanq u for giving the reply. U r attached liks is useful for the question , After  saw the first link i solved the problem.
Thanq U.
With Reagards
Niranjan.Ch
(7,793 Views)
Hi cheers,
Thanq U.
With Reagards
Niranjan.Ch
(7,793 Views)
Hi Niranjan,
I am glad it was helpful.
Priyank.
(7,788 Views)
