High-Speed Digitizers
NI PXI-5122
I have an NI PXI-5122 and want to look at frequency, gain in db and phase margin to test out it's capabilities. I have no DUT. Using a frequency synthesizer to generate a 10MHz signal to channel 0 of the 5122 Is there a canned vi to start from?
(6,711 Views)
In LabVIEW, select Help->Find Examples... When the dialog comes up, search for NI-SCOPE. You should find what you need.
(6,705 Views)
As mentioned above, the NI-SCOPE examples are the best place to start. Particularly for measuring frequency, you can start with "niScope EX Measurement Library.vi" and "niScope EX Advanced Measurement Library.vi".
Good luck!
Josh
(6,685 Views)
