High-Speed Digitizers
Does the 5112 Scope card have an onboard readable temperature device?
Scope spec suggests performing a self cal if ambient temperature changes by more than 2 degrees. I assume a Temperature device is located on card to allow determination of this?
(6,011 Views)
The 5112 does not have a readable temperature device. The specification recommends self-calibrating if the ambient temperature changes by more than 2 degrees C because within +/- 2 degrees C of the self-calibrated temperature is where we guarantee our specs. Once the board drifts beyond 2 degrees C from the self-calibrated temperature, gain and offset drift can affect your measurements. Please let me know if you have further questions.
Josh
(6,004 Views)
