High-Speed Digitizers
NI SCOPE PXIe-5114
Hello Dear NI Users,
First time I am using NI Scope PXIe-5114 model. There are some questions/problems I cannot handle with them.
There are some examples on National Instruments - NI-SCOPE - examples - DotNET 4.0 - VS2010, after installing NI SCOPE Driver.
Among the those examples, there are good ones which get AnalogWaveform data from PXIe-5114.
My problem is I cannot get voltage data from PXIe-5114 using C#.  There is DC (10V battery), measure it with NI-SCOPE Soft Front Panel and get value about 10V.(it means Front Panel shows correctly in mycase). But when I use examples I am getting values around 5 and this value is extracted from AnalogWaveForm.
It seems I minunderstood NI Scope or doing something wrong.
Can anybody advice or tell me or show some code how to get measurement data as Front Panel or other ?
Thank you
(5,110 Views)
Hi Mamur,
Have you tried this example: http://www.ni.com/example/26632/en/ ?
(5,084 Views)
