High-Speed Digitizers
PXIe-5114 Status Code: -223431
Has anyone seen this error before? My NI representative is unsure what this error relates to.
PXIe-5114
Internal Software Error occurred in Scopes software. Please contact National Instruments Support.
niScope Initiate Acquisition.vi:2<ERR>Internal Hardware Error occurred in MIG hardware. Please contact National Instruments Support.
Component Name: nihsdrk File Name: p:\Measurements\DHV\DSS\export\3.0\3.0.0f0\includes\nidss\tSMCRefClkPLL.cpp
Line Number: 214
Source: unknown (0): ??? unknown (0): ??? unknown (0): ??? unknown (0): ??? unknown (0): ??? unknown (0): ??? unknown (0): ??? unknown (0): ???
(5,096 Views)
There are a couple troubleshooting steps that I would recommend trying.
  1. Reset the device in Measurement & Automation Explorer. (If this fails, please post the error code you get)
  2. Reboot the PC or PXI controller.
  3. Try a different PCI or PXI slot.
I would also like to get the serial number of your PXIe-5114 if possible.
James F.
(5,074 Views)
Hi James
This is the MAX error I get.
I rebooted the PC and PXI controller, this clears the error but the error returns after running our application.
Tim
(5,065 Views)
