High-Speed Digitizers
NI USB 5102 Windows7 support
Hi.
Is NI USB 5102 oscilloscope supported in Windows7 and if it is which Ni-Scope version should I use?
Thanks.
(5,905 Views)
The USB-5102 is not supported under Windows Vista or Window 7 with NI-SCOPE.  Although I have not tried this, you may be able to get it to work using NI-DAQmx.  The 5102 is essentially an overclocked E-series DAQ board and can be programmed using either NI-SCOPE or NI-DAQ (it is the only scope card that is like this).  You may need a 32-bit version of the OS to get it to work.
(5,893 Views)
Thanks for reply,
If NI Max does not detect 5102 I am not sure if I can use labview VI's to talk to the card.
Looks like its time for eBay.
(5,883 Views)
