High-Speed Digitizers
NISCOPE_ATTR_CHANNEL_TERMINAL_CONFIGURATION Datatype mistake
Hi High-Speed Digitizers Users,
I have noticed a mistake in High-Speed Digitizers Help File (NI-Scope version 2.8.1f0) :
Specific Attribute
Datatype Access Applies to Coercion High Level Functions
ViReal64 R/W Channel-Based None N/A
Description
Specifies the terminal configuration for the channel.
Defined Values:
NISCOPE_VAL_SINGLE_ENDED—(0)
NISCOPE_VAL_UNBALANCED_DIFFERENTIAL—(1)
NISCOPE_VAL_DIFFERENTIAL—(2)
ViReal64 should be replaced with ViInt32 as in :
Channel Terminal Configuration
Specifies how the digitizer configures the channel terminal.
Valid Values
0—Single Ended
1—Unbalanced Differential
2—Differential
Remarks
The following table lists the characteristics of this property.
Data Type ViInt32
Access R/W
Channel-Based Yes
Where should I post this message in order to ask NI to update the help file for the next NI-Scope version ?
    Emmanuel
(6,119 Views)
I filed an internal bug report based on your post.  We'll fix this in the next version of NI-SCOPE (3.1).
Thanks for the bug report.
Patrick
(6,113 Views)
