05-03-2006 11:05 AM
| Datatype | Access | Applies to | Coercion | High Level Functions |
| ViReal64 | R/W | Channel-Based | None | N/A |
Specifies the terminal configuration for the channel.
NISCOPE_VAL_SINGLE_ENDED—(0)
NISCOPE_VAL_UNBALANCED_DIFFERENTIAL—(1)
NISCOPE_VAL_DIFFERENTIAL—(2)
ViReal64 should be replaced with ViInt32 as in :
Specifies how the digitizer configures the channel terminal.
0—Single Ended
1—Unbalanced Differential
2—Differential
The following table lists the characteristics of this property.
| Data Type | ViInt32 |
| Access | R/W |
| Channel-Based | Yes |
Where should I post this message in order to ask NI to update the help file for the next NI-Scope version ?
Emmanuel
05-03-2006 01:40 PM
