High-Speed Digitizers
Need Ni-SCOPE 3.5.2 for LV2009
LV2009 is ready. But I don't see NI-SCOPE 3.5.2 that is compatible with it. Where can I find it and download?
(7,738 Views)
The latest version is not yet available on the website, but should be on the Device Driver DVD that shipped with labVIEW 2009.
Doug Farrell
Solutions Marketing - Automotive
National Instruments Automotive Solutions
(7,726 Views)
Ok. But I found that NI-SCOPE 3.5.2 supports only LV2009 32-bit edition. What about the support for LV2009 64-bit edition like it's already made for NI-DAQmx 2009 or NI-Vision 2009?
(7,721 Views)
The next version of NI-Scope will have support for LabVIEW 2009 (64 bit) and will be available later this year.
Mark S
High Speed Digitizers
(7,701 Views)
The scope driver is now live on ni.com at the following locations.
https://www.ni.com/en/support/downloads/drivers/download.ni-scope.html
Doug Farrell
(7,665 Views)
So does ni scope support labview 2009 (64bit) yet? I am in dire need of it.
Thank you
(7,419 Views)
Unfortunately, it is not supported yet but should be as of the next release of the driver.  We are currently working to get this up and going as fast as possible to meet the demand of our customer's migrating over to 64 bit systems.  If this is an urgent issue I would recommend that you contact your NI Field Engineer/National Instruments Support to see if there is anythign we can do for you in the meantime.
Doug Farrell
(7,392 Views)
