High-Speed Digitizers
Oscilloscope/Digitizer persistence waveform
Is it possible to have NI digitizers show waveforms with persistence such as Agilent and Tektronix benchtop oscilloscopes? I understand ZTec modular oscilloscopes have this function. I guess it can be progemmed using LabVIEW, but is there an off the shelf way of doing it?
Thank you.
(9,209 Views)
Hi emc2006,
     When you are using NI Digitizers with NI-Scope Soft Front Panel you can save data and analyse later.
    But If you need datailed information about our NI Digitizers you can contact NI office of your region.
Abel
NI Brazil
(55)(11)3149-3149
Abel Souza
Engenheiro Eletrônico
LabVIEW User since 8.5
(9,182 Views)
Accepted by topic author emc2006
There is currently not a simple property or function that implements persistence for NI-SCOPE. Your interest in this feature has been passed along to R&D for future consideration.
You are correct that you would have the ability to program this feature in LabVIEW.  I would consider using an intensity graph. The x value would be your time, the y value the magnitude of your voltage and as you iterate through your waveform you would create the z values to show persistence of the waveform.  Shift reqisters can be used to keep track of the intensity from the previous iteration.
- Jennifer O.
Product Support Engineer - High Speed Digitizers
(9,164 Views)
Hello Jennifer,
Thanks for sending my suggestion to R&D, maybe we will se this feature in future LabVIEW releases.
If I manage to implement this feature using the current LabVIEW version I will post a messege on the forum.
(9,121 Views)
I wanted to do this and this was the only thread I could find on it - based on Jennifer's suggestions I managed the above
 persistence graph. I'm pretty pleased with the result, so I thought I'd share it.
Saved in Labview 2010.
(7,588 Views)
