High-Speed Digitizers
Output a +5V TTL on a PFI term. to a 50Ohm load (M-serie or S-serie)
I can export AnalogComparisonEvent to any terminal like PFI0. This signal is supposed to be a TTL with max = +5V.
But it seems the impedance of the PFI is not 50Ohm, because when I look the signal on a scope (terminated 50Ohm), the maximum is at only 2.4V.
Can I change this impedance ? How can I manage otherwise to get a +5V TTL on a (50 Ohm load) out of my card ?
Config. : a PCIe 6259 (M-serie) or a PCI 6110 (S-serie), with BNC-2110 or BNC2120.
Thanks !
(3,714 Views)
external hardware buffer/driver , powered by the provided 5V
Greetings from Germany
Henrik
LV since v3.1
(3,634 Views)
Thanks. So no other option than to use an additional external device that will amplify then signal, that's it ?
(3,631 Views)
If you use more that one PFI and parallel them ... but I don't recommend that.
read the spec, all expected behaviour..   If you increase the load impedance you get closer to to 5V.  50Ohm is no typical TTL input 😉
What is the problem? 2.5V is fine to trigger something 😄
Henrik
LV since v3.1
(3,628 Views)
