High-Speed Digitizers
PCI-5124 compatibility with PCI-X (PCI eXtended)
Can I install PCI-5124 to PCI-X (PCI eXtended) slot?
It physically fits but I want to make sure it will work and not be damaged
when it is powered up.
(6,485 Views)
Accepted by topic author musto
Hey,
The PCI 5124 card will work just fine in the PCI-X slot, as PCI-X is backward compatible, hence you shouldbe good to go.
NI-khil
(6,481 Views)
Thanks. I have already found the answer in the following reference:
PCI Keying and Voltage Compatibility
(6,476 Views)
