High-Speed Digitizers
PXI 5162 Digitizer memory allocation
Dear community members,
I got a question regarding how high-speed digitizers allocate onboard memory. Any clarification or help is very much appreciated! Smiley Wink
On 5162 digitizer user manual, about memory allocation:
Allocated onboard memory per record: [(Record length + 448 samples) × 2 bytes/sample], rounded up to an integer multiple of 128 bytes (minimum 512 bytes)
I am a bit confused about minimum 512 bytes in this case.
Even if record length = 1, then the allocated memory would be (1+488 samples) × 2 bytes/sample = 978 bytes, which is already larger than 512 bytes.
So it will never fall below 512 bytes Smiley Surprised
Could anyone clarify this? Or maybe this is a typo?
Thanks in advance!
Message 1 of 1
(2,853 Views)
