High-Speed Digitizers
PXIe-5105 two channel measurement
I am trying to do a 2 channel measurement by setting the other channel as the second channel. It works when the other channel is channel 0. I believe this is the default for the other channel.
When I tried changing the other channel to a different channel it does not work, it is always using channel 0.
niScope_SetAttributeViString (handle, otherChannel, NISCOPE_ATTR_MEAS_OTHER_CHANNEL, 0)
Is there another function call i have to call to commit the change?
(3,421 Views)
Please provide your vi(s) or code that setup the task.
Greetings from Germany
Henrik
LV since v3.1
(3,401 Views)
struct niScope_wfmInfo *arrayWfmInfoPtr = NULL;
  ViReal64 *arrayWaveformPtr = NULL;
  ViInt32 numWaveForm = 0;
  handleErr(niScope_ActualNumWfms(handle, firstChannel, &numWaveForm));
  handleErr(niScope_SetAttributeViString (handle, otherChannel, NISCOPE_ATTR_MEAS_OTHER_CHANNEL, 0));
  if (arrayWfmInfoPtr)
    free (arrayWfmInfoPtr);
  arrayWfmInfoPtr = malloc(sizeof(struct niScope_wfmInfo) * numWaveForm);
  if (arrayWaveformPtr)
    free (arrayWaveformPtr);
  arrayWaveformPtr = malloc (sizeof(ViReal64) * arrayActualRecordLength * numWaveForm);
  if (arrayWaveformPtr == NULL || arrayWfmInfoPtr == NULL)
    goto Error;
  handleErr(niScope_InitiateAcquisition (handle));
  handleErr(niScope_FetchArrayMeasurement (handle, firstChannel, timeout, SUBTRACT, arrayActualRecordLength,arrayWaveformPtr, arrayWfmInfoPtr));
(3,389 Views)
