High-Speed Digitizers
Property Node
Hi Devchander:
I have a question I would like to ask for a property node. Attached is the example.
You can see there is no "Plot Interp" after "ActPlot" that is created from waveform graph on the right in the block diagram. The one inside the for loop is the orginal one. How can I make the one exactly the same as the one inside the "For Loop."
What I am trying to do is to select another nice waveform graph from front panel to see if it  work, but the propery node that I created can not be the same as the one inside the For Loop. I don't understand why?.
(6,254 Views)
You can select which property you want in the property node by right click on the property and select properties >> ...
Or you can use the operate tool ("single finger" tool) and then click on the property and it will list all the properties you can select.
(6,247 Views)
