High-Speed Digitizers
Property Node
Hi Devchander:
I have a question I would like to ask. I have a property node question. For some reason. I could not send the vi file. I make a word document.
The one that is on the left is the property node I created from waveform graph.  You can see there is no Plot Interp after ActPlot. The orginal one inside the For Loop contains those parameter. Why? How can I make the one like inside the For Loop.
What I am trying to do is to select another nice waveform graph on the front panel to see if it work, but the propery node can not be created the one inside the For Loop.
The attached file vi is actually a niScope EX Multi Record.vi
John
(6,232 Views)
Here is the link to the same question in your other thread.  http://forums.ni.com/ni/board/message?board.id=150&message.id=1058&jump=true
(6,225 Views)
