High-Speed Digitizers
What ViString do I use to configure the NI5620 for External SMA Ref Clk In
The NI-SCOPE Function Reference for NISCOPE_ATTR_INPUT_CLOCK_SOURCE lists the option but does not seem to include a suitable value. Nor is it obvious in niScope.h what value should be used.
(5,908 Views)
The correct input string for this would be:
NISCOPE_VAL_EXTERNAL
You are correct that the function reference manual lists the incorrect information. This has been filed with R&D to be fixed in future versions.
Thank you for your feedback!
(5,908 Views)
