High-Speed Digitizers
What is the minimum trigger hold off time for the 5124
What is the minimum trigger hold off time for the 5124 i.e. what is the fastest i can collect data without streaming?
Mark Mutton
Electrical Engineer
(6,861 Views)
Good morning Mark,
Thanks for contacting National Instruments with your issue, we'll try our best to resolve it for you as quickly and efficiently as possible.
The minimum trigger hold-off time for the NI PXI/PCI-5124 is 2 us with TDC disabled and 10 us with TDC enabled.
You can take a look at any other trigger specifications for the NI PXI/PCI-5124 below:
https://www.ni.com/docs/en-US/bundle/pxi-pci-5412-specs/resource/371468e.pdf
Best of luck with your project.
Sincerely,
Minh Tran
Applications Engineering
(6,844 Views)
