High-Speed Digitizers
Where to download instruments drivers?
I need the instrument driver described in this link:
http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=E3B19B3E950B659CE034080020E748...
but I can't find the download button. Any help?
Message 1 of 16
(7,348 Views)
Hi Maggots,
I believe these are just the regular NI Scope drivers that we offer for free on our website. You can find them at ni.com/drivers. The latest such driver is actually 3.8.7 which can be found here: https://www.ni.com/en/support/downloads/drivers/download.ni-scope.html#307032 . Did you specifically need version 3.6?
Jason L.
Product Support Engineer
Message 2 of 16
(7,346 Views)
All right, I installed it but then shouldn't I have access to ni-scope functions in LabView? (Express > Input > Instruments Driver) I think I should have at least an initialize function. I do not undersand.
Message 3 of 16
(7,339 Views)
maggotsBrain,
You may have downloaded the incorrect version of NI SCOPE for your version of LabVIEW. I would double check the compatibility between the two. The NI Scope drivers should be in that location, but it is also in Measurement I/O -> NI - SCOPE. You may have to repair or reinstall the drivers.
Jason L.
Message 4 of 16
(7,325 Views)
I can't be using an inappropriate version of NI-SCOPE as it was sent on a CD with my device.
I'll try the path you recommend tomorrow.
Message 5 of 16
(7,319 Views)
What is surprising with this is that the NI-SCOPE soft front panel seems to work well.
Message 6 of 16
(7,318 Views)
Hi Maggots
What version of LabVIEW are you using and what version of NI Scope is bundled on that CD?
Jason L.
Message 7 of 16
(7,316 Views)
LV:2010 and NI-SCOPE: 3.8.7
Message 8 of 16
(7,314 Views)
Hi maggotsBrain,
I have the same thing installed, and this is what I see.  Can you confirm you do not see this?
-Andrew
Message 9 of 16
(7,308 Views)
Lucky you! I'll try to reinstall the driver.
Message 10 of 16
(7,305 Views)
