High-Speed Digitizers
Where to download instruments drivers?
By the way, what advantages confers a self-made program on LabView over the Ni-Scope Soft Front Panel?
Message 11 of 16
(3,666 Views)
Maggots,
The Soft Front Panel just allows you to do quick measurements with basic functionality:
  • Load/store waveforms
  • Load/store device-specific configurations
  • Make scalar measurements
  • Use NI-SCOPE utilities such as Auto-Setup and Self-Calibration
When you use the NI Scope with LabVIEW, you will be able to pull the waveforms into LabVIEW to process them in software. Programming with LabVIEW also allows you to do multiple device synchronization, handle continuous acquisitions, among other things. I would check out the examples folder once you have everything running. Navigate to Start»All Programs»National Instruments»NI-SCOPE»Examples to find them.
Jason L.
Product Support Engineer
Message 12 of 16
(3,664 Views)
I have reinstalled the ni-scope driver and now I have access to the same menu of that of your screenshot. However, I am afraid that the thing won't work properly as my hardware (a PCI 5105) was already installed in the computer when I reinstalled the software. This could be a problem as it is clearly said to install software before hardware in the manual.
Do I have to take the PCI back out and then in again?
Message 13 of 16
(3,659 Views)
Although the problem I mentionned, LV seems to reckognize my PCI-5105 because I can put itd MAX asigned name into the input name of the initialize function.
Message 14 of 16
(3,658 Views)
Accepted by maggotsBrain
Maggots,
I don't believe it matters too much if your card is inserted at the time of driver installation, it is just a good safety precaution to do so. I would just give your computer a restart after installing, and you should be good to go. The fact that your MAX and LV can detect the card is a good sign.
Jason L.
Message 15 of 16
(3,655 Views)
I guess it's going to be all right too.
Thank you for your help and your concern.Smiley Happy
Message 16 of 16
(3,650 Views)
