High-Speed Digitizers
error at aquire waveform VI tektronix 3032b using ethernet
I am using a tektronix 3032b with a built-in ethernet port. With technical support I have been able to modify the Getting Started VI so that it works using ethernet vs. BPIB. Everything runs ok until the Aquire Waveform VI. At this point I get a "Protocol specified is invalid" error. (-1073807239, HEX0xBFF0079).
(5,445 Views)
Hello-
Apply the patch at ftp://ftp.ni.com/support/visa/drivers/win32/2.6/patch/ and the problem should go away. Please write back if it doesn't.
Randy Solomonson
Application Engineer
(5,445 Views)
